tyler__820
I have a question to anyone who know the answer to my quetion. Would a posi unit out of dana 60 rear end fit in a dana 60 front end?
Yes they can but most likely you will need to change side gears because of spline count. I'm not sure though if you can swap side gears on all posi units though. My Powerlok has served well for over 5 years now and my hope is it slips before a axle snaps.
If you have a powerlock, you can buy a 35 spline side gear kit for it and pull your carrier apart and swap the side gears to 35 spline (even add a clutch to each side as well), then it will work, but its hard to find a powerlock that can do 4.56 and up gearing as i only see them in 4.10 and down, so if your running steep gears, you need a spacer with the 4.10 down carrier. We did this to my friends d60 front using parts from a dodge rear 60 powerlock.
how do you use your power lock?
and how well do you like the way it works?
i plan on using mine in my front 60 for plow truck use.
