mollyman
I think I am at last getting a dana 60 to put in my burb but it is drw and not the right gears. So I was wondering if anybody knows a good place to get a complete "rebuild" kit for a d60? I know there are a ton of places to get the ring and pinion and I already have a set of srw hub/rotors with the races in them lined up. I need install kit and all the seals and bearings (I know nothing about the d60). Also what is needed to change to the 35spline outers? Are mods to the hub required or do I just buy the new stub shafts and swich them with the stock ones. I also want to use drive flanges instead of hubs. Simply put I need to take the axle down to bare housing and then reassemble replacing everything as I go. Any help would be great, thanks!!!
