I have a Dana 60 from a 1986 K-30, M-1031 with a factory limited slip.
I'm using the ring and pinion and installing a grizzly locker.
The shop doing the install asked me for the carrier outer shims (the thick shims) that I seen on youtube, that goes between the carrier bearing race and housing.
But I cant find these shims.
I don't remember seen these shims when I removed the carrier from the housing. I immediately, using a plastic tie, tied the side carrier races to the bearings and carrier to keep them all together.
Question:
Could it be that the factory limited slip did not use those thick outer shims? or if all Dana 60's use them, then I must have lost them.
Thank you,
Ed
Question:
Thank you,
Ed
