Dana 60 Shimming Issue
Upstate
- In Memoriam -
New York
I used ORD shims to get the correct angle at the pinion on my 60 (front). Once I did it created a real issue with the U bolt pads. Do spin the u bolt side and elongate the other (pass side) and drivers side just spin the bolts?
If you put a 3degree shim below the spring, you need a 3 degree above the spring turned the opposite way so the spring plate sits flat.
So, I would take that as yes..my meds doesn't always allow me to be logical.
I wouldn't stack shims, buy the correct steel shim and use another on top of the spring pack as mentioned.
How many degree's are you shimming?
http://diy4x.com/product.php?productid=17721&cat=250&page=1
should a got this kit from kirt.
and yes stacking shims = HUGE NO NO . . . .
problem with this angle you need is alignment problems down the road . I would look in to what can be done to help driveline work with less of a shim degree correction . this will help keep caster more in spec for less problems with alignment / driving / handling / possible death wobble from so much shim correction angle change.
I am gathering between 8 and 10, issue I have is my brand new front drive shaft also binds at the cv at the front of my 205 I bought from you.
Real pisser on the driveshaft. Anyways, other than high pinion how am I correcting this?
wow just 6" and that much angle correction dam . . . .
hate to say it but always buy the shaft last or you will get the shaft :eek:
with my talking to jesse at had my 1 truck when ready will be fine with 1410 at the dana 60 front and 1 of his c/v heads . this truck will be on 8" springs .
the u-joint is prob killing you on working angles . and the shorter nv4500/205 combo don't help the front shaft .
Going back I wish I would of used the adapter even with the increased length. I could of use the factory front driveshaft from a K30, my twin stick install is a royal pain, no cross member works (too forward), and the list goes on. For everyone else, 6.0 motor, NV4500 and 205
