Dana 60 Spindle shim?
nightmare73
Colorado
Probably a dumb question, but I've searched the web and can't find it. I have angled shims between my spindles & knuckles. Are they necessary? They only go on two ways and each way seem to put severe angles on the wheels /---o--\ and \---o--/. It's a 90 CC with 6" lift and 35's.
They are aftermarket alignment shims for camber. I would suggest having the alignment checked to see if you actually need them.
I had them on my D60 as well - they added several degrees of negative camber. I removed them. No problems yet.
