I had the Dana 60 sitting on jack stands without hub/rotor and axles, just the spindles, approximately 18 inches high. I accidently knocked it over causing the passenger side spindle to hit the concreate floor of the garage.
today I installed the wheel hub on the driver side without any problems, the passenger side would not go on all the way. The distance between the rotor and caliper bracket is 1/4 inch from the driver side versus the passenger side.
Could I have bent the spindle when it fell?
