supersize75k5
OrganDonorRacing.com
Some parts from my buggy,
diy4x spring plates and shims, I recall these being 6 degree shims with u-bolts and grade 8 bolts 75.00
bunch of busted hubs.. i have a couple more sets somewhere else too lol, need a little part? Just ask
1 good 30 spline stub spare 45.00
couple bad stubs but with good yokes, cant recall if it was here or pirate but someone mentioned they wanted these to make drivelines, 15.00 for both
30 spline hub, just 1, i just bought off someone from a low mile cucv, paint is free. 45.00 obo good for a spare
dana 60 high steer y-link steering. The tie rod end was drilled out in a pinch, you can add a hiem" here or replace the 30.00 tre, the drag link is aluminum 1 1/2" od, the tie rod is sleeved 1.5 " 120 wall dom or 188 wall with 120 wall 1 3/4" over it, iirc 150.00
th-350 to 205 or atlas adaptor, im going to a 400, this one should allow you to clock your 205 or bolt up an atlas. 140.00
factory th-400 to 205 adaptor thin one 100.00
another th-400 to 205 adaptor, thick one, 100.00
brand new yj driveline, new yoke, tube, joints, was for a spring over yj 75.00
Im a bit rusty on the last two in terms of info but ill be glad to double check anything.
looking to pad my paypal account but will accept check, mo etc
Also I am not a next day shipper sometimes, I have been slow with it in the past and let others down to a fault, but I will make sure to try to get stuff out with in a day or two.
-shawn
-shawn
