dana 60 stub shaft
j250trxr
Registered Member
mn
I have two c-clip groves on the 60 stub shafts and when i pulled the shafts out there was only the one on the end. What is the inner one for? Today I recieved my new 11690 warn lockouts and they look nothing like the ones thet were in there i will see if i can get some pics in a bit.
Here are the pics should i put the new ones in like they are or should i remove the washer and two inner rings or is this just how the new ones are?
As far as I know just that 1 small snap ring on the stub shaft and the big one that holds the hub body in.
Are you replacing Auto hubs? I think auto hubs had a second one behind the hub body.
No the second pic has the original lockouts that were in there. I just think maybe warn changed them that much, maybe cheaper to produce by putting in a washer and two keeper rings rather than machining the whole part.
