I've got them in my D60 front and I really like them. Seems like a much better design for longevity and they won't groove your axle shaft. They do NOT fit unmodified however in my experience - I had to turn down the rubber cone and supporting flange that point toward the outside of the axle as it was too big to fit inside the axle tube.
I also had trouble getting them to install squarely at first with motor oil as a lubricant (they have rubber sealing ridges). I wrecked a pair in the process. I switched to white lithium grease and they went in with relative ease. I used a long piece of allthread, some nuts, and some large fender washers as an install tool - post with pics: http://coloradok5.com/forums/showpost.php?p=2653157&postcount=8
Used them in my GM D60 housing ,much better seal than the OE style & had no problems with the install , other than you have to make sure the insides of the axle tubes are cleaned out really good.
