Dana 60 ubolts?
JUNIOR-K5
SO.CAL
I just installed my dana 60 on my sub. today and the the two bolt that bolt on to the pumpkin are to long. I got the ubolt kit through superlift and Im running kerts spring plates. The studs are threaded on both ends and are about a inch to long. Threads are not long enough to tighten up can I use two bolts instead. Thanks.
Yes, go to your local hardware store and get new grade 8 bolts to the required length you need.
