Do I absolutely have to have a case spreader?
No, to get the carrier bearing preload spot on yes you do. I have only used a case spreader once on a D 70.
Did you make some set up bearings Matt?
Nope, you don't need one.
12 ton shop press, bearing separators, bearing pullers.
I've pulled the bearings on several other axles with limited success, I'm pretty sure these would'nt come off without a fight, which would end in their destruction.
OR, just pay the guys down at the local diesel shop the 150 bones to do it for me along with the new bearing kit. They have always done great work in the past.
or make a trip to Utah county and I can help you get them off and set back up again. It's a pretty easy job especially if the housing is out.
Most of the time I can get the bearings off without destroying them. The bad thing is sometimes the carriers aren't machined exactly right and it takes a couple of tries to get the preload and back lash where they need to be, so the bearings have to come off a time or three. I used to have some set up bearings for a 60 but I think I loaned them out and they never came back.
Holiday season is busy Matt I could come down with some setup bearings then we wouldn't even have to pull the old ones off.
But I am busy until January![]()
Eric, , if you've got the set up bearings, that would be great, Let me know when it's convenient, I'll get us some lunch and you some fuel money and we'll just make a day of it.
BigBlock72, thanks for the offer!Eric, , if you've got the set up bearings, that would be great, Let me know when it's convenient, I'll get us some lunch and you some fuel money and we'll just make a day of it.
I have the axle out and on jack stands. I'll start cleaning it up and get it ready to make the swap, that way it will go relatively smooth.![]()
I need to replace my inner axle seals on my front 60 and this would be a good opportunity to see how it all goes together.
