B
Bohemian
Guest
82 K5 Blazer
1310 Series Pinion Yokes Front & Back using Spicer 5-153x U-Joints
With the strap clamps on the caps for the u-joints fully torqued, there is up & down play between the ends of the u-joint caps where they but up against the square bosses that they butt up against in pinion yoke races/bores...
There's not enough play to put a clip or clips in that came with the u-joints, and there is no area for the clips to ride in IF there was; like is in the drive shaft itself to hold the clips & u-joint caps in...
Are my pinion yokes worn out or?
Seems odd the only movement is between the two square bosses the u-joint caps butt up against; but nothing on the diameter of the u-joint caps.
Am I missing something obvious?
Any existing links & or videos, pictures would be most welcome, not having much luck so far with my searching.
thanks in advance.
thanks in advance.
