suntadz
well I got a compressor, rebuilt it, got a bracket from taz, got some expensive crap from kilby, put it all together today and have some issues to iron out. Of course it couldn't work right the first time.
First off it wont shut off. guessing the pressure switch isn't working. Thats ok. built up past 160psi and almost pegged the gage.
When I rebuilt the compressor I also did the oil fix Ive heard mix reviews on. I tapped and plugged the little hole and put it all back together. Well I heard the downfall of this is the crankcase isn't vented after plugging the hole. So i thought I got smart and when I did a oil return line from the filter I put a tee after the valve with a stone type breather. Thinking this would vent the case problem solved. Well when I run the compressor oil pukes out of my breather pretty good. So I think I have a couple options. Plug the vent, rethink the vent, or take the compressor apart and unplug the hole. Anyone got any ideas on this?
