Dash lights? How many bulbs
Tbruz
Registered Member
Windham, NH
Trying to improve the visibilty of gauges at night but not remove dash.
1972 Blazer with Tach.
Indicators: 2 bulbs for turn signal and 2 bulbs for idiot lights
Gauges: 2 bulbs on speedo side and 2 bulbs on fuel gauge side.
Am I missing any?
Thanks,
Tbruz
That sounds right....IIRC the tach gets residual light from the other two gauges and doesn't have any of it's own bulbs.
:usaflag:
You can use 168 bulbs in place of the 194 bulbs to get more light and 161 bulbs to get less light.
161=1CP (candle power)
194=2CP
168=3CP
All three bulbs have the same wedge-type mounting configuration
I use 168 bulbs for illumination and warning lights. I use 194 for turn signal indicators and I use a 161 bulb for high beam indicator lamp because it is usually very dark when running with high beams on.
