I need a dash pad for a 74 K5, so I think 73 to 80 should fit W/O AC. Must be in good condition, been to the junk yard several times and had no luck finding a decent one.
The dash pad is the same for AC and Non-AC. The only thing different is the trim piece either covers the holes or has vents mounted in it. You should be able to re-use your old trim piece if you buy one from an AC truck.
