Yeah, I originally put the dash in the 75 about 2 years ago and modified it a couple of times for the guages. This time is the most practical. It is a lot of work, but not to bad if you have experience in custom fabrication with fiberglass. I use to build show trucks where guys would spend 3-7 thousand on a speaker enclosure. The hardest part is not turning back. You first have to cut out the metal original dash. If any one ends up doing this I can give you alot of helpful hints to make it easy. Another thing I did was modify the heat/AC system to actuated/electronic from the factory vacuum so I could use the 98 heater control module. Alot went in to it, but I have been customizing cars and trucks for 15 years and enjoy it. Patience and time is a big part of it. And don't forget to ask questions from many of the experienced people in forums like this. I know I have.
