Joe In Montana
- Joined
- Sep 9, 2016
- Posts
- 283
- Reaction score
- 109
I got fooled into changing the stepper motors on my buddy's dually and while I was in there I had to put in blue LEDs for him.
"No sweat" I said.
Well - it's not a bad job - really!
It takes some patience, a lack of fear and some sneaky tricks (concerning the LEDs especially) to get it all together again once repaired.
Unfortunately I did NOT take pixs, but I can say that the steppers are really easy to remove the old and install the new - buy the kit and do it right!
The kit includes a needle-puller to take the indicator needles off the shafts of the existing steppers.
They pull right off - but treat them carefully since they are somewhat fragile. There ARE custom needle kits though - which I didn't need for this job.
The stepper motor kit I got was from Dr. Speedometer. I can recommend it heartily. Be sure to order enough motors, since the Transmission Temp gauge requires a motor too!
In the Dr. Speedometer kit will be some incandescent bulbs - very tiny ones - and these are the same that you cannot buy from GM for those other tiny lights in the various switches in the interior. Save them!
The LEDs were from Partsam. These are very nice and you'll get exactly the right number of LEDs to do the job, including one for the Transmission Temp gauge. It takes seven (7) motors for that dashboard cluster - don't forget.
BUY a solder-sucker - available at Radio Schlack - it you can find one still in business, that is. You MUST get rid of the solder by either wicking it away (this works, but is messy) or sucking it out of the heated joints.
The sucker is the best. Get a quality one! You can use it a few more times in your life.
The LEDs are harder. NOT the installation - but figuring out the polarity of the places where the old incandescent bulbs lived.
Incandescent bulbs don't require polarity considerations, but LEDs DO!
I left the long legs on the LEDs to make them easier to work with --- and just temporarily spot-soldered them to the unit and then plugged it into the wiring harness. The ones that didn't light up --- were in backwards.
You can't really hurt an LED by installing it backwards - other than the fact that it won't light up. The longest leg is the POSITIVE (+) one. Don't trim them short until you know for sure where they go!
I used a hemostat to hold onto the positive (+) leg of the LED until I trimmed it to correct length. Marking pens won't do it. I know of what I'm saying here.
Just swap the legs - (shortening them now as you know which is which) - so they fit very close to the printed circuit board.
Tools you'll need:
To access the speedo cluster, first take the trim/reveal off the front of the dash - just pull it gently with your fingers, starting at the top over the cluster and working your way around the cluster.
This is a plastic press-pin fit and they will come out cleanly if you don't get froggy and use a tool like a screwdriver or pry bar. Use your fingers.
There is sometimes Velcro holding the edges tight - watch for that.
The cluster will next come out with (about) four (4) screws.
Once the screws are out, then reach behind it before you try to pull it too far out, and unplug the male connex by pinching it (it's hard!) and pull it straight out.
There may be another connection - look around!
Installation, as they say --- is reverse of the removal.
The first cluster's a little hard* - but the learning curve is almost flat - and if you do the first one of these - you'll be the neighborhood Mister Wizard.
(* maybe it's just a lot of extreme concentration - but it really is easy!)
I hope this helps. It's just nuts-n-bolts.
"No sweat" I said.
Tools you'll need:
- 30 Watt soldering iron --- NOT A BIG CLUNKY WELLER 3-SPEED GUN!
- Solder Sucker
- 50/50 or 60/40 solder (Doctor Transmission includes this!)
- Rosin flux (keep 'tinning' the tip of the iron)
- a CLEAN work station.
- Good lighting - especially if you're old.
