GMCJimmy84
Registered Member
I tried searching the forums for info on replacing the dashboard/pad and found some references but no real info. I figured I would start this thread for what I have learned.
My dash was cracked severly due to dozens of years of sitting in the sun. I considered a cover-up pad but I also wanted to check the wiring behind the dash due to rats making my truck home.
Removal was pretty easy, remove the screws around the dash and disconnect the A/C vent on the passenger side from the hose behind the dash. I found many rat droppings in the hoses, so I ran the shop-vac through as best as I could to get out as much as possible.
I bought a replacement dash, not from LMC as it would have been twice as expensive and the wrong color. I did buy the AC Vents and hose mounts from LMC. I intend to use the original chrome name plate/bar so I went to see about removing it. The plate is attached to the dash with metal caps that look a lot like a nut but aren't. They will screw off as I was told in the thread but some were hard to get off. I had to chip off some plastic to get a couple of them to back off.
Also my new dash does not include the metal clips that hold the dash in near the windshield, just a metal mount to attach the clips. I tore apart my old dash and it looks like I can use those. To get the clips out you have to lift up on the end furthest from the windshield edge, then slide the clip away from the edge and then turn 90 degrees and it will pop right out.
Another part to keep from your original dash is the defroster vents. The new dash did not include them.
That is as far as I have gotten so far, I will update my thread as I make progress on this part of my restoration project.
