Daughters 01 24 valve Dodge
Third gen wheels are where it’s at. Waiting on some 37”s to show up for my 01. H2s would be the only other wheels I would run, I had a set of the new style H2s on my third genView attachment 387277
If you haven’t done third gen front brakes yet, it’s a game changer. 1” bigger disks. Worth every penny. You just need caliper brackets and rotors for a third gen.
What I really need to do it a third or fourth gen steering swap. Brakes are actually good.
Oh but first thing to do now is fix the d70… pinion has a ton of slop.
And I still have a eye out for Ford lock outs.
So last week the Kate took her truck out for a drive she got back home and I noticed the pass rear tire going flat. I jacked the truck up and heard a wooshing of air. Great!
A sharp rock went right though the Center of the tread.
I took it to my tire guy and turned out that it was actually a chunk of aluminum that went through. No good way to fix it either.
A replacement tire was going to be 420.00!
I posted a add on Alberta coal rollers looking for a tire and as luck would have it a girl a hour and a half away in Calgary had two Cooper STT muds she didn’t need for 350.00
They only had 3000 Klms on them and she gave me a third tire of the same size for free, offshore mud with decent tread.
This is a pic of the chunk from the inside.
Shouldn't be too bad. Pull the carrier and pull the pinion. Look up service procedure and see what the torque is on the pinion nut. I had a Dana 80 go out in a Ford dually and it was a massive torque value for the pinion nut. Had to get my work to buy me a torque multiplier to do it. Did a quick search and it looks like it doesn't even use a crush sleeve to set the pinion bearings, just shims, so it should be pretty easy.
Thanks Luke! Got some reading to do.
Found a Dana 70 with factory disk brakes rebuilt for 350.00.
The guy had it on for 900.00 but it is now missing the rotors the new callipers. He has callipers for it. The e brake shoes are worn out.
Was thinking I could convert it back to drums with what I have if it checks out ok. Said some kid rebuilt it in school.
Didnt think a factory disk brake Dana 70 was a thing but after he gave me the numbers and I called them into the dealership… they made them for 1.5 years. Very rare!
my 02 has a disc brake rear; actually both my 02s do but the other is a dually
Yeah I was gonna say '02 only, they had the 60 front 70 rear discs all the way around and the 6 speed manual. But I don't like Dodges so I am not 100% on that.
Yeah but I bet they are D 80 the dually will be for sure. Not that I don’t want a 80 for it but they are more work to swap and way more money.
that is why I throwed the dually part in there; I was thinking the dually's had rear disc.
both of mine are automatics.
Spent some time in our shop making a spot to replace the rear end. The shop has been a disaster for years… not my doing but I finally got my in-laws motivated to cleanup a bit. Still a long way to go for my liking,but I got some room and don’t have to rush too bad to get this done.
You wouldn’t thing this socket would be such a problem? No parts store had one, my buddy’s didn’t fit. Spent a hour and made my own.
  • IMG_0850.MOV
    36.3 MB
Did anyone know that the mounting flange is totally different for the disk brake D70 than the drum brake version. Or did everyone know that besides me!
