uglytruk
- Joined
- Oct 24, 2004
- Posts
- 1,329
- Reaction score
- 0
I've always been annoyed that you couldn't see the hi beam indicator during the day.
So all 3 of my Subs and K5 blazer had burned out dash bulbs, so I took an extra minute to modify the dark blue plastic cover that indicates when hi beams are on.
It's really simple after you've removed the dash cover. Just use a sharp pin or pointy sheet rock screw. Push thru the plastic lense whilst holding against a piece of wood. The lense is too flimsy to do it on the dash.
All you need is the smallest hole. Too much and it'll annoy you at nite.
