DD dodge is getting H2 rims
DEMON44
Low-Tech Redneck
Okotoks, Alberta
1 done. Cut stock center cap to fit. Works good. Now just need 17" rubber to complete the deal. :D
there in the garage................which I noticed after I was finished. Got a little tunnel vision putting it on :doah:
I don't want to start a debate...but why would you need a jack stand for changing a wheel? It is probably the safest thing to do, if you can get one in place, but isn't that a little overkill. Yes, keep your legs out from under the vehicle...which shouldn't be hard to do if JUST changing a tire. No doubt you should have a JS if under the vehicle...
Just curious is all...
Joshua
Did the same thing on my chevy. :D
How much 'customizing' did you need to do to your center caps? Looks good.
The Dodge centers are different than those GM ones. Mine are snap-tite not thread on. I had to cut the plastic skirt about 3/4" then the metal retainer. about 1/16"-1/8" so it would fully seat inside the hummer rim.
dyno'd today.............242RWHP on a mustang dyno...................517ftlbs
Not bad for a stock engine...........factory rated at 235hp :doah:
just a baseline # now though.................Its on its way up.
