I guess I'll open this idea up for discussion. I may or may not have a parasitic drain, so I did some investigating.
Truck - 2004 Yukon XL 2500, 179k
Battery - Optima Yellow Top
Aftermarket Radio - Alpine head unit with EQ unit
Aftermarket Amp - 2 JL Audio 300/2, 1 Phoenix Gold XS2500, Focal Component, 2-10" Subs
So I looked on YouTube about testing parasitic drains and found one by disconnecting negative cable, and place a meter between the two to see any parasitic load present. What I found was a total drain of 0.07 Amps (70 Milliamps). YouTube suggested 50 Milliamps or lower is acceptable.
The first drain was the hot wire going back to the 3 amplifiers. Once I took that fuse out, I got a drop of 20 Milliamps (sitting at 50 total now). I then pulled the radio fuse from fuse box, I dropped another 30 Milliamps. So with those two removed, my net parasitic drain for the truck is now 20 milliamps total.
To me, that doesn't seem like a huge amount to drain the battery over 2 weeks (vacation sitting at airport).
I tested the voltage of battery, I think it was about 12.5V. I started the truck turned on the radio, headlights, HVAC....battery voltage at idle was about 14.5V. Does this tell me I have a good alternator charge?
Where do I go from here?
