My new GM crate engine with about 5000 miles on it developed what sounds like a valve train noise. I started the truck up a few days ago, and it started to misfire real bad. I opened the hood , and removed the air cleaner lid. I could see that one of the TBI injectors was not firing at all. I pushed down on the TBI electrical connector, and it started firing the injector. My truck was running normally after that, but when I started to drive down the street at about 2000 RPM I heard what sounded like a loud valve train rattle.
I turned around and went back to my house. I opened the hood again, and grabbed the throttle lever by hand. I revved the engine up to about 2000 RPM, and could not hear any valve train noise. I then drove down the street, and heard the same valve train noise again. Apparently the valve train noise will only happen when the engine is under load. Then I grabbed my stethoscope, and listened to every part of the engine there is. I could not hear anything. So, I parked my truck and called it a day.
I had to go to work the next morning, and I drove my truck. The truck started to make the valve train noise again, but this time it started to develop a bad miss fire.
These are the tests I have done so far to try to diagnose this problem.
1. Stethoscope, no noise found
2. Remove valve covers and inspect (no loose rocker arms or cracked valve springs)
3. Remove all spark plugs (all plugs look normal)
4. Compression test (all cylinders check out at 145 PSI with no leakage of pressure)
I do not expect any replies will help this problem because it is one of those problems that you have to be there to get any understanding of what is going on.
