Alright guys,
I am having some issues with the front end of my K5. A little back ground first, 86 K5 with 1 tons and 37" GY's, ORD crossover and 1.5" tie rod with TRE's. Ord steering box weld-in plate and bolt in brace also installed.
I was having some "death wobble" issues while driving...or so I thought. So this past weekend I pulled the front end apart to check everything out. Found that all wheel bearings were somewhat new, still had good grease. So I cleaned,checked and re-packed the bearings. Inspected the upper and lower kingpins. Found everything to be in good shape.
So with everything back together, I go for a drive. Everything goes great until I hit a pot hole with the right front. Then as soon as I hit that pot hole the entire front end starts violently shaking from side to side
!!! I had to come to a complete stop for it to go away.
I need some input as where to look now. Not sure if my leaf spring bolts/u-bolts are loose or what???
Please help
Eric
!!! I had to come to a complete stop for it to go away.I need some input as where to look now. Not sure if my leaf spring bolts/u-bolts are loose or what???
Please help
Eric
