TWiSTeDBLaZeR
Registered Member
Ok...just welded on ORDs weld in kit. Was hoping i would not have the DW anymore, but that's just not how it goes i guess.
I did the up and down check on the the tires while on jacks. The right side has alot of play...the left side not as much. This weekend I will be replacing the wheel bearings. I Just forked out alot to repair the frame and am limited this week on what i can use. My choices are Balljoints and wheel bearings or packed calipers and rotors. I think the ball joints and wheel bearings. Where do you think i should go with it?
