Decent cheap lockers?
Holeshot
Minnesota
Who out there makes some decent lockers that are pretty cheap? I have heard of the lock-right, detroit EZ and some others but I would like some opinions on them. The biggest tires it would see would be 35s and a 350 most likely.
Ahh crap. I am an idiot.:o Its for a GM 10 bolt. I cant believe I forgot that little detail!:haha:
Lockright works just fine in my 14BFF. Locker in a 10B might be an accident waiting to happen, especially with 35" tires.
Yeah as far as a 10 bolt being a problem, the truck just has 31s but may see bigger tires in its future. I think maybe a 14 BFF might be the thing to do. I am not sure though. Thats why I was looking at cheap lockers rather than something expensive. The truck probably wont see bigger tires for a while and if/when it does have problems I would probably throw in a 14 BFF and maybe put the locker in the front. So is a lockright the best thing for the price really? And how long would it take to install? Thanks guys!
Newbie a couple hours . After the forst couple times its cake . I do mine every six months to inspect it . Easy .
Also get some Redline shockproof oil , it sticks to the metal components very well .
pauly383k10 said:
Avoid Detroit Ez or Quic Loc ( Detroit Ez in 4wp house brand ) . Get a Powertrax Lockright or no-slip :thumb:
X2 I broke 4 E-Z lockers in yrs with only running 33's.
ive got a lockright in my front 10b and i love it. it was only like $220 and a simple install.
I run a powertrax in the rear and a lockright in the front on 33" and it works great
got mine from summitracing.com.
they're fast, cheap and sent me a free hat lol.
I run a lockright in a 12blt with 35's. Haven't put it to any real test yet but it seems to work well. Bit of a pain on the street and not too nice for a daily driver. It's quite noisy even if your careful with the throttle in a turn. Try to pull out of a side road a bit quick and you'll have a howling tire behind you!
I was going to put one in my DD too 'cause they're cheap but I don't think I could live with the noise and tire wear so that'll be getting a lsd.
Lockright are cheap and real easy to install.
One heads up for everyone using them though.: I checked my cross shaft for hardness as they suggest and it was indeed hard. Couldn't file or cut it. After 400 miles I pulled it out as I wanted to change my brake plates and there were bad indentations on the cross shaft.
I spoke to Lockright and they said I needed one of their hardened shafts made for this application. They didn't make special shafts when I bought my locker so I figure they've had a lot of problems with wear so made a shaft for it.
Yea Mark, when I bought my NoSlip, it was with a hardened shaft. That was a 10b rear. LockRite for the front 10b didn't require any special shaft. Maybe they had already fixed that. BTW, they both work great.
Last time I bought a locker for a 10b jegs was the cheapest by a couple of bucks
