PA Decent prices on d60 and other parts
all my years i have not seen my self a set of 4.56 factory . yes i know there out there but i have never seen a set . if i had to guess 4.10 as most common and or this late in production possible 3.73 .
not bad prices for east coast rust belt . . . i got 2 dana 60 front housings all good threads and main caps . some knuckle stuff and brakes . package deal someone can have it all . . hell i prob got 12 dozen sets of core calipers .
Depending on location I might be interested.
Agreed that 4.10’s are the most common and are usually the standard ratio for 350’s, 6.2’s & 454’s if no ratio is specified and for the 292’s a 4.56 is standard with the other two ratios being optional in the K-30’s.
Also, cab chassis 6.2’s often use a 4.56 as the standard gear.
And of course the CUCV stuff was all 4.56’s but I think you’re talk’n about civilian trucks.
From all that I’ve personally put my hands on over the years the 4.10’s are the leader in C-20/30’s & K-20/30’s but 4.56’s are a close second with 3.73’s coming in last as least common.
Just a list of some K-20’s & K-30’s ratios that I’ve delt with or have passed through my hands - none of these were CUCV’s.
1966 K-20 Burb 292 420/221 4.56
1971 K-20 350 465/205 4.56
1973 K-20 350 350/205 4.10
1975 K-20 350 350/203 4.10
1978 K-20 292 465/205 4.56
1978 K-30 C/C 292 465/205 4.56 Tow Truck DRW
1978 K-30 C/C 350 465/205 4.56 Fire Support Truck DRW
1979 K-30 292 400/203 4.56
Crew Cab SRW
1980 K-25 400 400/205 4.10
1981 K-30 C/C 350 400/205 4.56 Crew Cab Fire Support Truck DRW
1981 K-30 C/C 350 465/205 4.56 Tow Truck DRW
1982 K-30 C/C 350 465/205 4.56 Farm Truck Flatbed DRW
1983 K-3500 454 465/205 4.56
Crew Cab DRW
1983 K-30 C/C 454 400/205 3.73 Fire Support Truck DRW
1985 K-30 454 400/205 4.56
1988 K-30 350 465/205 3.73
Crew Cab SRW
1991 K30 350 4L80E/205 4.10
Crew Cab SRW
1991 K-30 6.2 4L80E/205 4.56
Crew Cab DRW
Just pointing out to always check the ratios on a set of axles that are for sale on our civilian spec’d squares - 4.10’s a safe bet but 4.56’s are fairly common too ( especially on Cab Chassis trucks ) and from my experience the 3.73’s are the least common on K-30’s.
Like ya said 3.73’s does seem to be a little more common towards the later models from things I’ve read and listings that are posted.
Crew Cab SRW
Crew Cab DRW
Crew Cab SRW
Crew Cab SRW
Crew Cab DRW
My 1991 crew cab had 4.56 it was a 350/4l80E.
My 1985 crew cab 6.2 was 4.10, same as the 1980 with a 350.
Never got my hands on a 3.73, but my friend who bought my 1986 crewcab C&C diesel 2wd with 4.56 ended up changing the gears to 3.73 for better mileage.
I am now a proud owner of that axle. Been sitting in my backyard for 15 years
