Earlier this year I was gung-ho for doing a hydroboost setup but after reading about some issues with having a ram and you need to send it to a place to remove the restriction I think I might stick with a vacuum booster setup with the larger dual diaphram 11" booster and keep things simple under the hood. Has anyone had success with a GOOD vacuum booster/master setup with 4 wheel disk brakes?
I see ones like this from CPP and I know others have suggested the C30 aluminum master with a good booster.
