Decisions decisions
Muddytazz
1 ton status
Salem, Or.
How would be the best way to do things.
Currently my head unit is controlling 4 sony explode 6x9's (1 in each door of the burb). I installed a 4ch amp and 2 subwoofers also now.
Would it be better to just leave the 6x9's connected to the head unit and the subs on the amp or run everything thru the amp?
Amp = Volfenhag ZX-7160
6x9's = XS-V6933
Subs = Pyramid PNW10590 10"
And I don't want to hear about getting new stuff, cause I'm using this stuff until I can afford something better.
6x9's = XS-V6933
Whats the power and impedance specs for the amps and subs? This will definitely affect your decision, as it affects how the subs are wired, and how much power is distributed to the system from the amplifier.
Max power output 1000W (250W x 4ch) @ 2ohms
Power Output
340W (85W x 4ch) @ 2ohms
200W (50W x 4ch) @ 4ohms
Bridged power 170W x 2ch @ 4ohms
2 ohm stable
Tri-mode capable
Fan Cooling
Variable Bass Boost: 0 - 18dB
Variable Bass Frequency: 30Hz - 100Hz
Channel Seperation: >60dB
Signal to Noise Ratio: 90dB
THD 0.03%
Frequency Response: 20Hz - 20KHz
HPF: 50Hz - 1KHz
LPF: 30Hz - 250Hz
Adjustable Sensitivity Range: 0.1V - 1V
Input Impedance: Low Level (10K Ohms)
High Level (100 Ohms)
Power Output
2 ohm stable
Tri-mode capable
Fan Cooling
THD 0.03%
HPF: 50Hz - 1KHz
LPF: 30Hz - 250Hz
And the impedance of your subs?
All I can remember off the top of my head right now is.
Peak: 1000W
RMS: 500W
4ohm
Peak: 1000W
RMS: 500W
4ohm
Well, with dual 4ohm subs you can either wire them up to two channels of your amp (leaving two open for 6x9's), but that would only send 50watts to each sub. Just bridge the amp and run each sub to the bridged channel. That way each sub will see 170watts.
