So if anyone on here knows me they know I have had my fair share of axles in the past. Ive had 60s with 35 spline all the way through (and broke 60s) to a set of rockwells sitting in my shop right now,And no they aren't going in this rig. Here is where im currently at right now.
My blazer has 38s (good tread) on 15x10s with a welded dana 44 and 488s. Toy joints in the front driveshaft, 14 bolt in the rear with a Detroit and 1350s in a slip yoke. My truck works great for what it is. This weekend I rode with rigs all built way beyond mine and broke 1 warn hub (was my intention for that to be the fuse, just didn't think it would fuse as fast as it did
) and 1 stub shaft which was my own fault for acting dumb (got hung up and frusterated and was taking a retarded line).
Now I rode all day yesterday no breakage, 1 warn hub on the long side, 1 flange on the short side. factory inner and outer and a spicer joint. Note ive only ever broken one d44 joint and I think that was due to it being old.
Now after all this long winded speech, I plan on running these 38s for a long time (well the wife says so
) so in my mind I really don't feel as though I need a 60 YET (not never, just yet) so im thinking of buying a set of d44 4340s. My only real thing is I don't want to get out there and the 4340s be barley stronger than my stock shafts and be disappointed. I run a factory 700/208 not clocked nothing. I wheel with 1 ton double up rigs and Toyotas that are built. I just have to pick different lines.
what do you dudes think? If I go 60, its going to be a while with my funds.
Oh and no pics no proof, Here is the trail we rode where I broke my stub.
and here is my rig.
) and 1 stub shaft which was my own fault for acting dumb (got hung up and frusterated and was taking a retarded line). Now I rode all day yesterday no breakage, 1 warn hub on the long side, 1 flange on the short side. factory inner and outer and a spicer joint. Note ive only ever broken one d44 joint and I think that was due to it being old.
) so in my mind I really don't feel as though I need a 60 YET (not never, just yet) so im thinking of buying a set of d44 4340s. My only real thing is I don't want to get out there and the 4340s be barley stronger than my stock shafts and be disappointed. I run a factory 700/208 not clocked nothing. I wheel with 1 ton double up rigs and Toyotas that are built. I just have to pick different lines. what do you dudes think? If I go 60, its going to be a while with my funds.
and here is my rig.
