Bare knuckles are $259 each, spindle stud kits are $18.00 per side (6 studs), High Steer arms are $300 for the pair, and the studs for the top of the knuckle are $10.00 each. The $10.00 studs are GM studs with the larger center section to index the arm tight before you even put the tapered nut on it.
Is it considered bling if it's pretty AND works? If so.......Let the Bling run free!
All our crossover or high steer arms are now like the one in the pic, 5 holes for the knuckle and 2 holes in the front of the RH arm, one for the tierod, one for the draglink. If you don't have Dedenbear knuckles, you just don't use the 5th hole.
