so i stripped the 203 i got for my doubler over a year ago. and the main input/output ball bearings made there way under my bench grinder/drill press and ended up getting full of metal shavigns. so i found a doner 203 for the bearings. well as i drilled and started to tap my original gear box i started looking at the mess inside of the box and thinking of just drilling and taping my donor gear box and leaving the idler gears in so i dont have to mess with the 60 (or so it seems) needle bearings and washers/spacer. im thinking i can just stuff a rag in it to block all the shavings and the one hole i gotta drill where the idlers gears are just not drill completely through?
what you guys think?
but i was able to knock the pin down just enough to slide the fubared washer out and slide the new one in. hopefully the little ear on the washer can go ethier side. we'll find out i guess
