When you made these did you relief cut one side to keep the pin from binding?
How Much?
is there plans for degreed ez-inches?
Got my shims in today. Look great!
How about pics of those D60 shim plates in #1455, 65, 75 and 85?
Ok, yeah it makes sense. I was under the impression you made a one-off fancy plate for the top. Using a regular shim works fine.Same as pictured above. Just flip 'em over to set the spring plate back the other direction again.
I'll grab some better pics though.
Can you still machine the relief on the 4 degree shims for the bolt head to sit squarely? If so, I'm considering buying 4 shims if you can do the reliefs.
