*Delete*Both Trucks Sold Please Delete I will repost Cummins
jltait
Registered Member
MIDWEST
87- 3/4 ton Roller project no Engine; $5000 Firm (the blue one) TH350 and NP205 still in truck, 14bolt rear/Dana 60 Front 4.56 Gears Detroited rear, 37x12.50x16 swamper SSR's. Skyjacker 6" softride suspension, had all new sheet metal and never been on the road during winter or offroad since. I have much more detail and pictures for this truck than I can include here so send an email [email protected] will sell together with the cummins engine and all cummins installation parts I have for $6400
1992 Cummins engine and matching A518 2wd automatic; $1600Firm 160hp 400lb-ft bosch ve pump version. have all accessories; starter, alternator, heater grid, intercooler, etc. Have the 2nd generation round mounts. tranny coolers, this was a complete take-out
85-1 ton 6.2 diesel pickup $1600 with 168,000 miles (the brown one)runs great I drove all the time till the rear brake line just went. I have hauled plenty of fairly heavy loads. (near, at, and just over 3000#) and this truck handled it all just fine. It has been converted to a 700r4 beefed up slightly with an np241 case I commonly get 18mpg with this truck. This truck has 14 bolt rear/dana 60 front as well. This one is 4.10 ratio however.
$7500 takes both trucks, cummins engine/tranny and all cummins parts I have, spare th400/np205, extra suspension parts(including brand new BDS 4" rear springs and slightly used 4" Tuff Country front springs), Extra Pro comp adjustable shocks, both trucks have the big 4 core radiators, extra new LH fender. Need room want to work on my Chevelle!!, Located near Lansing, MI
$5000 takes the blue truck as a roller with th350 trans/np205 transfer case, 2 sets of header 1 fits small block the other fits big block and are coated. May include spare matching th400/np205 for asking price
$1600 takes the k30 1 ton brown truck as it sits runs/drives broken rear brake line.
$1800 obo takes the cummins engine, intercooler, wiring, 2nd gen mounts, intercooler lines, and anything else I can think of later that goes with the cummins.
$300 for matching th400/np205 originally from the brown '85 1 ton tranny has a crack in tailhousing area near where the transfer case would bolt did not affect operation but leaked alot of oil. I beleive this could be tig welded without dissassembly.
Oh yeah the Dodge tranny goes with this too.
Almost forgot,
the dodge tranny on the cummins goes as well this will be easier than adapting the cummins to the GM tranny. The tranny is 2wd but they have a bolt on overdrive unit. I was going to get everything in and lined up as 2wd then buy the 4wd overdrive unit and swap it onto the tranny with an earlier dodge t-case.
JLT
Location In Michigan
I am located in The Lansing Area of Michigan, Delivery may be arrangable within a 100 mile radius or so.
JLT
Springs
Goose,
I want to wait and see if everything sells together. If I don't get what I want out of this price wise, the project may move forward and I will need the springs, Thanks for the inquiry.
JLT
Breakout pricing for individual purchase
Okay I'll try seperating out the trucks.
$5500obo takes the blue truck as a roller with the th350/np205 and headers to fit a small block and another set to fit a big block.
$2200 obo takes the cummins engine, tranny, intercooler, wiring, 2nd gen mounts, intercooler lines, and anything else I can think of later that goes with the cummins.
JLT
Reduced Prices
Cummins $1800obo
Blue Truck $5000 Firm as described
Brown truck no change
Ben,
PM me if you would like and I will send you pics of the worst points of the truck. Structurally very sound, That being said the cable corner and rocker on driver side are broke through. The tailgate lower swivel point is also gone (this is common) I think the truck has 1 or 2 other small holes. Underneath very solid however.
Jason
Ben,
I do have everything for a TBI setup still, although the pump in the tank has been updated to a higher volume pump to run Port injection. I had an 8.1 litre from a 2001 sitting in the engine bay at one time but then decided to use it in my chevelle. Later when fuel prices went through the roof I decided to do a cummins swap, but now am looking to focus on one project (my chevelle) and want to get rid of some stuff. I think the pump in the tank would work ok as long as the TBI pressure regulator worked correctly but I am not positive. I would also have to go digging for the ECM/harness to be sure I still have it. I am sure I have it somewhere but I have moved twice since removing the TBI engine so locating it could be a chore. I stored stuff at two different locations while moving and have not brought everything to my current home. I do also have a complete TPI system from an '86 TPI camaro that I could part with along with the truck if someone were interested in TPI, so keep that in mind as well. You would have to give me a couple weeks to get up to my dad's to locate all the TBI pars.
Jason
more pics of 85 1 ton as requested
All,
here are some more pics of the 1 ton as were requested
Jason
Now on Ebay Item number: 110165442571
see ebay Item number: 110165442571
Thanks for the Link
Jeff,
Thanks for posting the link I had not thought about that.
JLT
Please delet posting
Please delete,
I only have cummins left but I will repost IT
