Pretty clean squarebody before the upgrade. Some of the new upgrade parts include:
Delete will consider full or partial trades. Trade for 1 ton pickup
- LS engine, 6.0, refreshed, 243 heads ($2,500)
- 4L80E full HD rebuild and HD TC ($2,000)
- Edelbrock Pro-Flow 4 programmable EFI ($1,150)
- FI Tech Standalone Programmable Transmission Controller ($650)
- NP203 T/C adapted with Northwest Fabrication plate (for all wheel drive, passenger side drop) ($150)
- 14 bolt SF rear 3.73 ($400)
- All new brakes ($400)
- Rancho 2” lift (ORD) ($300)
- New Billsteins all corners (ORD) ($460)
- Crossover steering with 2WD box ($400)
- Crossover Sway Bar (ORD) ($400)
- High Clearance Crossmember with LS motor mounts (ORD) ($400)
- Holley exhaust manifolds ($240)
- High Mount A/C compressor adapter, with new compressor, custom fittings ($1,000)
- Dakota Digital Dash and T/C VSS output ($950)
- LED Headlights ($200)
