That would be awesome! Let me know what you find.I did at one point but forgot to label them. I likely still have them but I'll have to look.
Nope, the brackets have a wider pattern for the 75-76 grills. The screw mounting holes are spread further apart than on 73-74 models. GM oddly bent new brackets just for 75-76 GMCs. 75 chevys even had different brackets that had the mounting holes above and below the grill instead of inside the grills. It has taken me 8 years to realize all of this. Lol. Got tired of the billet grill and bought a 75 grill and of course I’m missing the bleeping brackets.Aren't the '75-'76 GMC grille brackets the same as '73-'74 Chevy and GMC?
I should have a set but cannot find them at this time. I'll let you know if they turn up.Nope, the brackets have a wider pattern for the 75-76 grills. The screw mounting holes are spread further apart than on 73-74 models. GM oddly bent new brackets just for 75-76 GMCs. 75 chevys even had different brackets that had the mounting holes above and below the grill instead of inside the grills. It has taken me 8 years to realize all of this. Lol. Got tired of the billet grill and bought a 75 grill and of course I’m missing the bleeping brackets.
Thanks bud! Fingers crossed here.I should have a set but cannot find them at this time. I'll let you know if they turn up.
Nothing at the moment.Do you have any half ton dog dish hub caps?
What ones are you looking for? Can you find an image?Do you have any half ton dog dish hub caps?
What tires are those?
I might have one or two.Do you have any half ton dog dish hub caps?
Nothing in good shape.Would you happen to have a complete 85-88 grille for the dual headlight option?
I have a pair of large bearing hubs and spindles if you want to convert but nothing for small bearing.Looking for 1/2 ton Dana 44 front hub with the small bearing (1973-76).
I might have a pair. I will check if I sold them yet.Looking for 1/2 ton Dana 44 front hub with the small bearing (1973-76).
