Deleted
Best when you realize you came up with bad assumptions because you are working on stuff while exhausted.
I hate that. Makes you feel dumb when you walk out there later and fix it like no thing. At least it was an uneventful fix
Long story short, I was chasing a no spark issue because I used my timing light to determine if I had spark. But, a bad spark plug stops the circuit and I only found the issue because I decided to go back to the beginning and check with a random loose plug. Bad plugs and the distributor 180 out combined to be the issues. But it runs good now.
