WA Deleted
I've never tried to use the wiper mounted nozzles on the older arms. I could check. The wiper blade attachment is different though. The attachment at the wiper transmission spline is the same and interchangeable.
Well no big deal then but I’d like a clean set of later model black ones. Are they stainless under the black? What I have now are aftermarket ones rusting. Hideous.
They are actually not stainless. Older ones are just silver paint.
@thatK30guy Wes, are you still interested?
Yes! Just not on here very often. I have new aftermarket grille and headlight bezels in the shop waiting for installation. Here are the pics of the damage on my C30. Looks like I need the upper trim and driver side trim around the bezel. I don't know if the headlight buckets need replacing until I get everything apart.
The upper and lower trim are identical, just rotated 180 from what I can tell. I would need to see what I have for shipping tubes for that piece. The fender trim fits in a medium flat rate and would need to ship separate.
It looks like your center trim survived. I do not have any headlight buckets for the quad headlights but I do have adjusters, springs, and misc hardware.
If you can fit the side fender trim with the long trim thats fine and cheaper than paying 2 shipping fees
do you have a front drive shaft that will fit np205 1310 u-joints 30 inches?
shot in the dark...........
With it without the 4 bolt flange? I have a few.
SM465/NP205 about 25" compressed (left)
TH400/NP205 about 29" compressed
with the flange, need t400 np205 one what do you want for it?
the spot it goes measures from the flat of the flange to the u-bolts is 30 1/8 if that helps to get close to fitting
Is that fully compressed or mid travel in use?
Then the second driveshaft from the top should work for you. $50 plus shipping. PM me your zip code and I'll get a total with shipping.
@thatK30guy you mentioned you had a new aftermarket grill and headlight bezels .. I have the exact front grill and bezels .... I was wondering where you ordered yours from. I have looked at LMC Truck and a few other places and trying to get the best price and best products and wondered if you had any recommendations
I got them off eBay but I can't find the seller I used as I got all three parts for something like $89 with free shipping.
Here's a link to similar ads and you can scroll down to see other sellers doing the same deals.
I'd be in for all the lmc seals except the 5958 and 6948. Let me know what ya need to ship to 80301. Thanks
