modernbeat
...Curious if anybody has ran into this problem on 14 bolts before. I am sure open to some ideas
Larry, while I have not seen it on a 14 bolt (because they are rarely in roadracing cars) I have seen similar puking from a lot of axles, particularly the 8.8 installed in recent Mustangs with the Traction-Lok LSD.
What I've seen is that clutch-style limited slips or lockers add a LOT more heat into the rear diff fluid than Torsen style LSDs or selective style like the ARB. The extra heat first blows the fluid out of the vent, then starts taking out bearings and seals and eventually can even affect the brakes in a racing application. In most cases when I can change it out to a Torsen, the heat is reduced tremendously.
But, this heat really on shows up when racing, and working the differential action, and the locking, much more than what the designers thought the car would see. If you aren't experiencing a lot of wheelslip, or cornering hard, I'd look and see if something else was causing the differential locker to work when it shouldn't be working. Something like one of the rear tires being taller than the other.
