So I'm looking at the grimjeeper gear ratio calculator and I'm playing with the numbers if I were to use a STaK 3 speed case. I like my combination of 4.10's w/ the 38" tires because it gives me really streetable gearing and great HWY fuel economy. However, off road I could use some more gearing. Not that I'm going to be able to get a STaK case any time soon... but I'm just playing.
So, what sort of crawl ratio should I be looking for? Right now, I've got a 205 behind the 465, so I have an overall low crawl ratio of 52.72. This is pretty good for most crawling I've done, but I'd like to have something much lower every now and again - particularly snow and technical rocks.
With the STaK 3 speed cases, you get some options which is cool. Their highest ratio option would give me 55.14 and 100.86 ratios for the low ranges. That sounds like all the gearing I'd ever need. I'm attracted to that set up also, because it doesn't make the first low range too low for general trail riding.
The other two give me 65/116 and 82/146. Ofcourse, the crazy low second low ranges sound cool, but I don't think the first low ranges would be particularly trail friendly because I'd have to be in my highest gear to go what would still be too slow for the easy parts of the trail... I think.
So, if you were in my position (and if my position were actually one that could buy a STaK
) what would you think of all this jibberish?
