I had this issue when I first built the Jimmy. Everything was new, except the wiring harness. Try holding the throttle open a little and start moving wires at theback of the block then start working forward. Was an intermitant issue. Turned out to be the harness to the TPS. Under load, the harness moved enough to kill it.
