AUK5
ok i know a lot of you want soft tops and no one makes them and we never know if can-back will actually start producing them. so our only option is searching forums and hope one comes up for sale (like me) and get lucky. or go to a boat shop and make the canvas. while you make the supports. i have a STC fasttrac. here are a bunch of detailed pics of all the componets. sorry its kind of dark. if you need measurements or better pics tell me and i will gladly take them.
Drivers side rail
front mount and drivers side rail
Cab mouting
Cab mount
Looking down on driverside to show the bar support with top down
bar support with top coming up
Support extended
support realeased to put top on
rear channel to hold top down
Starting to put top on cab mount
underside of top showing how it mounts to the bars
bar support realeased
top on without side windows (zipper for window)
Side window
inside showing bars supporting the top
Little bars that tighten the front of the top
Rear support bar
Back inserted in channel
truck with top.
Like i said i can go get measurements and more detailed photos. i hope people will be able to use this any time a question comes up aout softops. No one makes them as current. so make your own at a boat shop.
Ryan,
Hope this helps.
Drivers side rail
Cab mouting
Cab mount
Support extended
Side window
Rear support bar
truck with top.
Ryan,
Hope this helps.
