determining cam specs for a chip burn?
rescue6
Registered Member
Colorado
I am trying to put a TBI set up on my 85 GMC burb and have most of the parts sourced to do it but will need to get a chip burned for it to properly run. My problem is I know that it has a small cam installed in the engine but I dont know the specs on it. Is there any way to tell the lift etc or will I need to just buy a new cam so I know all of the specs for a chip burn? Thanks for the help.
You *really* need to have a datalog to get a good burn.
In actuality, it would be much easier for you to do this, and probably not much more, if any, expensive, then have someone like Brian at tbichips.com burn you a chip to work with what you've got, than to swap cams just so you know what it is.
So I should just try what I have now I have a 1227747 ecm and it has a chip for a 350 and a manual trans. then get the winaldl program and harness and get the data. Is that what you are saying?
That is what he means. The datalogging will tell Brian everything he needs to know to burn you a proper chip.
thanks, I will just have to do it that way then as soon as I get the rest of the parts and put this thing together. I am just trying to get everything lined up before I dive in on the conversion.
If i were you i would first see how much vacuum the engine makes with the cam you have in the engine, if it doesn't produce at least 17 inches of vacuum then the cam is too big and won't work with FI.
thank you for the input I will check on that first thing Monday.
I have a ALDL cable that I will sell for $25 (I will be posting this to the for sale section soon). It has a serial end on it and bare pins on the other end. It does not work with my 16147060 ECM and laptop set up (8192baud). I will be buying a different USB cable from ALDL cables.
Let me know if you are interested.
Not true, just more work and I've never seen it done mail order. Only hands on.
So I want to get the TBI to work on a 400 small block, how does this data logging thing work? I hook up the aldl cable and run it with what its got?
Yes, click data logger and only select sensor data. Then go to BLM and coose wide avarage. Try to fill in as many boxs as possible. When your done driving around click save data in BLM then save in data logger and post the files here. We can see how far off you are.
Cool, i'll get a cable and hook it up, hopefully the truck will be together by the end of the week. Thanks.
Just be careful, your setup is going to run lean at WOT, if not at all other ranges as well. Datalogging isn't going to tell you much about WOT without a wideband O2 sensor.
Yeah what he said.... :D So don't go melting a piston at WOT to start. ALDL is going to get you tuned from idle to about 3400 rpm. Wideband O2 sensor is really needed for top end.
So how should i run it to get enough data? I would definatly take it easy because i know its not going to run right.
Exactly! :D
Just try to fill in boxs in the Wide BLM table. Half throttle and drive around town. If no SES lights come on take a little highway cruise.
