Detroit Locker inside.....Install questions
mrk5
The Sticker Guy
Moderator
Vendor
Author
Northern Colorado
Thanks to Tim's Offroad for locker, bearings, seals, & ring bolts. /forums/images/graemlins/thumb.gif
I feel like I'm entering a new level of the off road driving experience. /forums/images/graemlins/peace.gif
So basically how hard is it going to be to install this bad boy?
FYI: It's a C-type locker for a 12bolt.
I guess my biggest concern is wether or not I'm going to have to set up the gears again. I haven't read the instructions yet (too impatient). Can I leave the pinion be and just bolt the ring gear on with the same shims that were on the old carrier?
Also, has anyone ever heard of using a piece of paper to set up gears?
[ QUOTE ]
[/ QUOTE ]
that will get you close, if not correct. just check the pattern adjust acordingly. /forums/images/graemlins/waytogo.gif
Well I just read the instructions, and they make it seem real simple.
*Just measure from here to here on the stock carrier.
*Move everything to the detroit.
*Measure from here to here.
*Figure out the difference.
*Install shims to accomodate.
*Put the Detroit in.
/forums/images/graemlins/thinking.gifNow if only it will actually go that smoothly. /forums/images/graemlins/shame.gif
Any other "things to look out for"?
Double check your backlash and run the pattern just to make sure. You never know what you're going to get.
Thanks for the props, and take pictures! I need pics of my customer's trucks for the soon to be released Tim's Offroad website. /forums/images/graemlins/thumb.gif
