Ned Kelly
I forgot to mention - when real slippery or snow on the street, I drive in 4wd just like 'Loafer' mentioned. I also use 4x4 on the highway when the conditions are bad, but a also don't do over 60mph (or slower, whatever is safe given the road/ice/snow conditions) and have no problems. As I stated before, I never regretted having a Detroit locker in the rear, and would do it again.
I like the ARB, but it is pricey. If I could afford it, maybe. I know fellows here you have had trouble with ARB's in the winter - maybe they just need an air dryer or something to help keep it functioning better in the cold. The local utility company ran some ARB's on their vehicles but found them to be alittle problematic due to icing up (improper install method for cold climate - maybe air dryer would solve this?). If you can do a job on installing the ARB and knowing it won't ice up, I would prefer the ARB over the Detroit. I think the first set of rear tires that don't wear out would offset the cost of the ARB - that's if you run a big expensive tires.
