OrngK5
Registered Member
Hey, calling on all you K5 gurus out there again, an issue has come up with my brakes or braking system. I have to push the brake pedal to the floor for it to generate any braking power, and hard too. This happens while running or while turned off. There is no air release at all after any pumps on the pedal, and no back pressure, the pedal just goes straight to the floor and immediately back up. I have not touched any part of the braking system whatsoever other than checking the reservoir fluid level, and it appears fine.
Has my master cylinder gone bad? There are no leaks around the inner wheels, or any fluid leaks from the lines leading away from the reservoir. Thanks in advance for any help!! I searched earlier, but all the problems from other members developed after replacing the MC or bleeding the brake lines, which I have done neither.
