did i buy the right product to run my lights,cb, ect
so i woud run the light to the relay to the fuse panel to the battery??? i hate electronics
Run (1) circuit from the fuse panel to the hot wire on the relay usually #30, ground 85, lights signal 87, and a trigger for the relay 86 can be parklights or direct frome the fuse panel circuit so you can turn them on any time.
thats all in some foreign language i cant nderstand man! sorry if you can simplify it a little it would be awesome i appreciate it
ok i think i understand now. i should use a switch then connect that switch to turn the relay on/off and send power to my offroad lights through the relay. but what is the thing labeled 30?
30 is always a hot wire from the battery of a source of power
