Only got the front two done now as other things have gotten in the way but I'm pleased with the results.
I grooved each block in two and then siped each of the blocks. Takes about an hour to do the grooving for each tire and about 35-45 minutes to do the siping. Had to get my technique down so the first tire took probably twice as long. Also helps to have a fan aimed at you so you aren't breathing in ALL the fumes.
Thanks to mrk5 for all the advice.
