four_by_ken
Yup, you beat me to it.diesel4me said:No, a diesel needs much more air--in fact,a diesel is like having an open intake with NO carb on it,running wide open all the time,even at idle,it needs 100% of the possible air it can get(and turbo diesels stuff even more down its throat!)--this is why diesels have no vacuum,there are no throttle plates like a carb to restrict the air flow,thats why they need a vacuum pump to run things that normally would use manifold vacuum on a gas motor.....Air filters get dirty REAL fast on diesel,since so much air passes thru in a given amount of time,compared to a gas engine....![]()
Air hogs they are. The more fuel and air you can stuff in the more power you will get.
hahhhaaa
I always spray water from the inside out so that the dirt is push out and not in...not sure if that makes sense...but it always looks new when I am done.
