uglytruk
- Joined
- Oct 24, 2004
- Posts
- 1,329
- Reaction score
- 0
I have a few 6.2's and a 6.5, and was filling my '84 Suburban with whatever coolant I had lying around. I made a video of that, and someone commented that I should be using a heavy duty cooland and/or additive. I looked that up, and found an interesting blurb on ebay.
I also read a bit about the subject on this forum.
My '84 Blazer gets hot climbing the hill I use to get to work, as It's pretty steep, and I have a snowplow blocking the grill. I really wouldn't mind using the water wetter stuff I found on ebay if it'll help the engine run a bit cooler!
Here's the comment I got from a watcher of my vid
>>I saw the new/old vid of you putting coolant in your radiator. I know it sounds stupid (I thought so too at first), but that cheap stuff isn't conducive to long life from a diesel. The combustion is so fast and so high pressure in a diesel that the cylinder liners expand and contract rapidly. When they contract the water immediately around them boils and then the bubbles contract with immense force - eroding the metal (cavitation). I'm not a diesel mechanic by trade but I've torn down one diesel that had holes clear through the liners. Don't take it the wrong way, but a GM/Detroit Diesel V8 would appreciate any help it can get. Heavy Duty Coolant has phosphates and/or molybdates to prevent cavitation - you can get bottles of additive too. Either way expect an extra $15 to completely fill it from empty. But what about a diesel ISN'T more expensive? <<
Here's what I saw on ebay...
[SIZE=+3]TWO BOTTLES OF FORD DIESEL COOLANT SYSTEM ADDITIVE TREATS UP TO 8 GAL. OF COOLANT PREVENT ENGINE WEAR Cavitation, or cylinder liner pitting, is one of the most talked about articles on any diesel board. About 99% of light truck diesel owners don't know what it is, but they are scared of it. Cavitation is essentially, the erosion or pitting of the cylinder liner. Small vapor bubbles actually drill through the liner or engine block or heads from the coolant into the combustion chamber. This causes rapid coolant loss, and oil/coolant mixing. This is by all means, not a good thing. Damage such as this requires either new sleeves pressed into the block, or engine block or head replacement.
Here's the link to the ad
http://cgi.ebay.com/ebaymotors/FORD...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
[/SIZE]
[/SIZE]
